city17
The original fence on my Inca bandsaw was missing, so at the time I bought it I got a very cheap Axminster fence. It fits the saw well, but it was simply too flimsy and had a too much flex. I found some other aftermarket fences too expensive, so decided to make my own with aluminium extrusions.
Wanted to share it as some other people might be in the same situation with a vintage bandsaw without a fence, and this basic design can be adapted to any size bandsaw I think. Overall it cost me about €40-50 in parts. If you get the parts locally it could be even cheaper, maybe €30 (shipping costs are high on extrusions).
Fence
It’s made of a 4080 extrusion for fence and a 4040 extrusion for the track. The fence is mounted on a glider specifically made for this extrusion model. I’ve added a corner bracket for extra stability. The fence is locked with a bolt from below and from the side to the corner bracket.
At the front of the fence is an aluminium plate, the top two holes screw into the extrusion, while the bottom is used for the locking knob. By tightening the locking knob, it pulls the aluminium plate flush with the track, guaranteeing you get the exact same fence position every time.
Glide track
To get it parallel to the blade, the track is adjusted instead of the fence. The track is connected to the table with two aluminium L-brackets. These have slots routed in them, so that the track can be moved forwards and backwards slightly. That way you can position the fence parallel to the blade.
Because the fence always locks in the same position, if the track is correctly angled, it will guarantee the fence be parallel to the blade.
Resaw bar
I’ve also added a resaw bar, made from a circular aluminium extrusion. It can be attached to the fence with two bolts and glide nuts. I never used a resaw bar before, but was surprised how well it works.
I’ve also designed a 3D printed flip stop which can be used a depth stop.
WIP
Although the basic design works well enough, it’s still a WIP and there’s a few opportunities for improvements. One flaw is that the miter gauge can’t move all the way to the front of the table due to the 4040 extrusion being in the way. A simple solution would be to rout/cut a slot in the track at the specific position of the miter slot.
Another issue is a little bit of flex at the far end of the fence. Actually I haven’t noticed it to be a problem while using the saw, but it would be nicer if there were no flex at all. This could be solved by adding another 4040 glide track at the other end of the table.
To adjust the angle of the blade more quickly, one of the M8 bolts used to attach the 4040 glide track to the angle bracket could be changed to an M8 star knob. That would make it very easy to adjust for blade drift quickly.
Another feature that could be added is a low rip fence, made from a long L-bracket with holes which bolt into the lower slot of the extrusion with sliding nuts.
Fence
Glide track
Resaw bar
WIP
