xy mosian
Hi all. I am in the middle of making a curve fronted cupboard for swimbo. Nothing really fancy just a softwood face to a melamine faced chipboard three-sided corner. The time came to make a plinth.
Now I didn't have a lump of wood big enough to make it from one piece, I don't have a bandsaw with the required depth of cut either. One of my options was to fabricate it, pictures show the process used.
I built the core up from odd scraps in the manner of a brick wall around a well, as you can tell I wasn't too bothered about the inside surface. Norm uses a windy nailer to tack pieces as the glue dries, I don't have one so I used poridge power, a few panel pins and a manchester srewdriver.
You can see from this image that the front 'veneer' was cut from a board, bent with water and a heat gun and rabbit's feet etc and glued on. Although the result is not perfect, it is solid.
The front veneer was cut, by hand, from a re-claimed soffit. Nice stuff that '70's softwood.
The larger piece to the top was left to allow screwing to the underside of the cabinet.
All in all I'm fairly chuffed with myself, one of Norman Stanley Fletcher's 'Little Victorys' I think.
Thanks for looking,
xy
Thanks for looking,
xy
