Not an awful lot left for me to say really!
I'd have suggested the latest issue of F&C too, but Philly beat me to it.
The debate between cambering the blade of smoothers and just knocking off the corners is a hotly contested one. Better woodworkers than I haven't been able to decide, so try both and see which you prefer. I have, and I
still can't make up my mind...
One theory against the corner method is that you end up with a scraper at each corner, which can produce a rough finish. In practice this is so miniscule as to be irrelevant I think, but FWIW.
Details of using a cambered iron to joint edges can be found
here, but DC's books go into it much greater depth.
Esp, my take on the jack plane's iron is this: The curve is there for a different reason than a smoother of a jointer. A smoother has one to prevent "tram lines" appearing in the work from the corners, and a jointer's is mainly to facilitate edge jointing (unless it's being used as an uber smoother, but let's not confuse things...) However a jack is there to remove quite a bit of wood in order to flatten the board. You want to take quite a chunky shaving to do this, if you don't want to be all day, and doing so with a square iron is hard work. I can't describe it at all well, but imagine a square iron trying to take a thick shaving, and then imagine a curved one. If you have a chisel and gouge of similar size handy you can replicate what happens, although rather exaggerated. The curved shaving will have the full depth of cut in the middle, but it tapers away to nothing at the edges, while the square shaving has to take the full depth right across its width. I'm not sure the exact proportions, but that's quite a percentage more wood you have to push with every plane stroke. A more extreme example of this is the scrub plane, which takes chips more than shavings, and has a really quite pronounced curve to the blade. Does any of that make any sense? :? It's a sort of trade off between finish and speed in the end I suppose.
Tsk, and I wasn't going to say much too... :roll:
Cheers, Alf
