Create a Paneled Room in Walnut Veneered MDF
danmosheim
30 May 2008
doreset, vermont, usa
We’re wrapping up a walnut paneled room in Weston,VT …. We’ve been working on it for a month or so. The client wanted a project that looked like solid wood without the solid wood budget. I took a technique I had used for paint grade panels, essentially strips applied to sheets with moldings added, and, with a little extra care and material selection, was able to create the look of solid wood at considerably less expense. More construction details, background info and CAD drawings on our blog at our dorset custom furniture blog http://dorsetcustomfurniture.blogspot.com/
just can't seem to get the picture thing .... sometimes it works, sometimes it doesn;t ... this morning, and this afternoon, they showed up in the preview , and the post.... hope they stay there
Now you see them, now you don't; Something to do with local cache I think, they appeared in original posts on my machine after I downloaded the images via a direct link.
Can't make out exact reason but suspect it may be down to spaces in filename. Here's a temp hosting for those that can't see them.
