Leg mortice tenons for a bench.
I have a 25mm auger bit but was wondering if I should widen the tenon a bit more, maybe 35mm? They seem a little narrow to me at 25mm. 45mm depth with 5 mm play possibly for 1/2mm drawboring if i can manage it. :?
Shaded area is the leg, tenons are on the bearers of course. Its keruing. Theres approx 1.2m between the legs and full length of top is about 2.3m.
I'd be glad if some could enlighten me before I start cutting. If I was to widen the tenon what would be the minimum width you'd leave on the mortice to be safe? Bearers and legs are flush fitting. (in theory at least! )
Chris
Chris
