Correct moisture content for turning?
gasmansteve
21 Sep 2007
North Yorks
Hi all
I`ve acquired a cheapo moisture meter which is giving a reading of 20-25% saturation taken on the ends of some 6-8" diameter elm (I think) logs that I cut up and sealed with old gloss paint I had about a year ago. This months Woodturning has an article by a guy making a vase with an initial moisture content of 40% and turns out fine. What moisture content would be deemed ok for turning without eventual splitting please or does the type of wood determine this?
Steve
Wasn't that the Tracy Owen article?
If so,I'm sure it was quite thin-walled,and it may warp slightly as it dries (although if so,will not detract from the piece in any way)
And timber type will also affect it - I've had kiln-dried cherry that's changed shape whilst being turned,and sweet chestnut that's been slightly damp but very stable.
Andrew
Hi Steve
Use your moisture meter to check, if you can, any timber in your house (architraves?) that's your starting point... the average house is about 8-12%
... assuming the timber is 40%, what will happen to the piece when it loses the remaining 25+% if it is to reside in the house.....
Steve I find that I can get away with it as Graham says at 12% without too much movement, in fact the very process of turning and sanding usually drops it further.
Some green turnings I have done have lost 30% + off the meter reading by the time I have finished (centrifugal dispersion and warmth drying from cutting and sanding)
On close tolerance items I start at 8% or below (off the meter) then let them acclimatize for a day or two indoorsbefore final finishing just in case they move.
Tried various timbers in the house and got barely a flicker on the meter (fortunately :lol: ) the meter starts to read at 14% so not really reliable below that, maybe trial and error to see how it does.
Steve
