Long post:-
I'm intending to build a glass fronted corner display case. I've done some woodworking from time to time but not done it frequently enough to really hone my skills. (I've read lots, though! ) Nevertheless I want to tackle this project. I have a good quantity of Oak which I can prepare to suitable sizes and lengths from broken up old furniture. I have the tools, the bench, and the time.
My design has a single front door 400 mm wide and about 700 mm high. The sides come out at 90° from the walls of the house for 100 millimeters and then meet the front at an angle of 45° (or 225° if you prefer.) Both sides and the front door are glazed.
There will probably be three glass shelves above the bottom. The style will be plain and simple - something between Shaker and Krenov if that makes sense.
I want the minimum of wood getting in the way of seeing the contents, but obviously the cupboard needs to be strong enough to carry the weight of the china and other ornaments/objects on display. What sizes of wood for the base frame, the sides and the door frames would be suitable, do you think? I would probably choose to dowel the frames together, although I appreciate that mortise and tenon would be the classic joint to use.
I was considering a French cleat (well, one on each wall) to support the cupboard and should I consider supporting brackets underneath also?
I'm sorry this is a long and complicated question but some general guidance would be very useful to me, thanks.
John
John
