Duiker
Hello good people,
I have a few questions which I'm guessing you will know:
Can anyone recommend a medium priced, cordless, circular saw which wont wear the battery down in seconds and can still cut decent thicknesses of wood? I dont need to cut down trees or anything but if I'm going to spend a few hundred euro's I want to get the best I can.
If you want to cut mitres along the length, or grain, of a piece of wood what is the best way to do it to ensure a good cut? I've been using the bandsaw but its not really good enough. The table on my table saw doesn't tilt either so I guess I'm going to have to spend more money right?
The last question is about building wheels. How do you mark out the wheel itself (assuming it is built from several "blocks" rather than from one piece and cut out)? I thought of clamping the pieces together, marking them with the "compass" and then joining them later but I'm not sure if it would work?
Once you have this done how do you work out how to drill the spoke holes for the rim and centre?
I know it is a lot to ask but so far you guys have been great and I just know you can help!!!
Cheers,
Mick
Cheers,
Mick
