edmund
Finished my console table (and drawers!) at last.
http://www.filehigh.com/viewgallery.php?f=22036
I'm quite pleased with how this has ended up as I designed it from scratch and wanted to do some traditional carcass work and drawers - neither of which I have done before.
I designed the table to fit in a particular space in my entrance hall - the full picture makes it look rather tall and unbalanced but it works better in the flesh so to speak as I designed it to fit under the dado rail.
The carcass and drawer fronts are black walnut. The drawer sides and backs are oak and the bottoms are cedar. The inlay on the drawer front is ebony (3.4mm square lines). The drawer knobs are ebony, which I turned myself to a non pre-planned design. The top was a bit of a departure and is tropical black granite (which I rather like and it fascinating to look at in detail); I think it works reasonable well with the piece.
Carcass size is 35" wide by 11" deep and 33.5" high. The granite is 1" thick.
I finished the piece with shellac then wax.
Interestingly, after I started making this I changed job and my new route to work takes me past some amazing antique shops. One of the pieces in the window was a console table. It had a pink marble top and a mahogany carcass with the front legs carved in the form of seated greyhounds. I found out it was made in the late 18th century for one of the palaces in Venice. There was a pair of them and they were £80,000 each! :shock: Don't think I'm quite up to that yet
Ed
Ed
