SteveF":1mys113n said:my brother recently had this done
which got me interested in diy option for ours
p.s. his cost 7k
Steve
Grayorm":20doyd4o said:This then crosses a boundary. To be a conservatory, (which doesn't currently require building regs) it must have a translucent roof. Once you put on any form of covered roof it is potentially an extension.
SteveF":30wxo049 said:I understand the tiles are light weight but
the marine ply
breathable membrane
insulation
plasterboard
surely put a load of weight on the ally struts?
Steve
Grayorm":1f0byfn0 said:The spars rest on the frames which will spread quite easily unless you use ties across the width of the conny.
Steve. Just read up. The glazing of 75% of the roof and 50% of the walls to conform as a conservatory was dropped in 2010.
WELL WORTH A READ
http://www.telegraph.co.uk/property/pro ... -roof.html
Grayorm":m9q8jres said:The spars rest on the frames which will spread quite easily unless you use ties across the width of the conny.
WELL WORTH A READ
MMUK":asp413n7 said:Grayorm":asp413n7 said:The spars rest on the frames which will spread quite easily unless you use ties across the width of the conny.
WELL WORTH A READ
I knew regs had changed but I wasn't quite sure exactly how, I don't tend to deal with planning apps these days.
