concealed hinges for curved carcass?
flanajb
11 Mar 2009
I am planning on making a piece of furniture similar to that shown below. The only difference is that I am not planning on having fully rounded carcass ends, but 50/75mm radius corners.
http://www.google.co.uk/imgres?imgu...&ndsp=23&ved=1t:429,r:20,s:0&biw=1495&bih=645
Just wonder what hinges I could use that would enable me to have a full shelf inside the unit. Given the doors will sit inside the frame and I do not want visible but hinges I am not sure what would be suitable.
A standard kitchen type concealed hinge would work and you could hinge the door on either side.
Knife hinges would also work and be less obtrusive but a bit more fiddly to fit, you could only use these on teh "square" side of the door.
I think the SOSS hinges might be the best bet. I did consider the knife hinges, but as the door is curved the door edge would protrude into the carcass when open as a result of having to mount the hinge further in from the back edge. This will reduce available shelf space.
Thanks.
