Hi all,
Finally got started last night, its a right pain when work gets in the way
My Breif:
design and build a corner table to display some decorative candles.
Materials:
2.5" x 3/4 Pine.
Here goes:
initial design sketch
After cutting to rough length, clamping up the top (right) and legs.
I had to make a circle cutting jig (i'll add pic of it) to create the top, this was the result. i am quite chuffed first attempt !
I wanted to do something to the legs, so they didnt look boring, so i decided to create some cut outs. i used the off cut from making the circle as a template for cutting an arc in the bottom and outside edge of each leg.
After cutting legs to same length on cross cut saw, then cutting the arcs out on the bandsaw and the cutout bit on the inside of each leg, glued the pairs together.
Thats as far as i have got so far.
Advice: how to attach the top ?
The legs will slot together and for a + sign when looking down. So, glue top to the top of the legs ? will this be strong enough? add some dowel pegs ?
comments/advice welcome.
My Breif:
Materials:
2.5" x 3/4 Pine.
Here goes:
