Competition WIP - Can you guess what it is yet?
Jorden
11 Jan 2005
Leicestershire
After a lot of thought, I've finally settled on something I want to build that conforms to the specifications of the competition, storage with a curve. I don't think that the curve was meant to be a round hole drilled in wood, or a rounded edge to a square box, so I've learned a little about steaming for this project. The origonal design for the steamer was simple, a piece of plastic soil pipe with a rag at each end and a wallpaper stripper providing steam.
Problem was, the pipe got a little hot and melted in the middle, so what started out as a 2 meter straight soil pipe, finished up as a 1 meter pipe with a funny shaped end.
The strips of oak and ash were cooked for 30 minutes then dropped straight into the bending jig 8 at a time, the jig closed, then my wife stood on top of the jig while I put the clamps on - teamwork :) The ash was no trouble at all and bent on the first try, but the first lot of oak broke 3 sets of sticks before I changed the peice of timber I was cutting the sticks from and was sucessful. I think the first oak I tried was too old and dry having come from a piece of dead furniture, whereas the second supply was from a virgin plank.
The next picture shows the jig to hold the frames in place while I pair them up.
Can you see what it is yet?
Dennis
Hi Dennis
Thanks for that.
Can you please reduce the size of the photos? They are 1024x768 and will be a real pain for people on dial-up.
Neil
Newbie_Neil":1b97so52 said:
Hi Dennis
Thanks for that.
Neil
But they are only 124Kb, so they might be large, but they aren't large files.
Adam
Give a cigar to the man with the iron tablesaw :D
Yes it is going to be a small pair of drawers in a cabinet for storing passports (human and equine) and other important papers.
Good going Philly :)
Dennis
Thought I'd post an update picture which shows more clearly what the finished cabinet will look like :)
The drawer fronts will match the carcase (having been cut from it). The top and base trim/feet will be in oak. Not decided on the finish yet.
Joining the oak rings to the ash ones was fun, it seems the oak retains the bend better than the ash, so a fair amount of fiddling/cussing/sweating took place while building the carcase. In the end a makeshift jig came to the rescue - the 3rd jig I've had to build just for this cabinet! :shock:
Dennis
