jlawrence
Hi all.
Well, I've finally made a start so I thought I'd better post my design.
My brief:
to design an build a loft style bed with desk underneath - both to safe for use by a 6 year old.
materials:
The whole lot is going to be made of recycled wood - in this case pine as that's what all my son's bedroom furniture is made of.
First design:
The picture shows some of the ideas I had. I've settled on using the square (ish) legs - these have worked out at 100mmx75mm.
Although I've shown external dimensions in the picture, the only dimensions set in stone are the internal ones which obviously need to be able to allow his matress to fit. The dimensions in the picture give a rough idea of the sort of sizes I'm using.
I'll post some more WIP pictures shortly.
The wood has all been purchased and prepared.
The long safety rails and frame sides have ended up being 40mm x 150mm x 2100mm. The length has been left over size and will be brought to the correct length later on, the reason for this was that swmbo hadn't decided on what sort of legs were needed at the time I prepared the rails.
Joints on the bed will be pretty simple, just a trench out of the legs with all the rails and ladder parts bolted in place. This will make it easy to take the bed down should we move.
The biggest issue I've had so far is the size of the wood I'm working with, it's difficult to manoeuver around my small workshop and sizing wood this size has proved a big challenge.
I think from dry fitting a few bits that this will be one very substantial bed - certainly more than capable of supporting a 6 year old safely.
The design of the desk won't be completed until after the bed is built. This will allow be to check the exact amount of space avaialble and check sizing against my son and his chair.
My brief:
materials:
First design:
