Hi.
Got a secondhand 1/2" collet for my interwood overhead router. Which are like hens teeth by all accounts.
Tried it this morning and I'm have a problem with it. It takes the router bit fine. You can easily pull it back out
before you tighten the nut up. Problem is once you've tightened it. Very difficult to remove it. Even when you remove
the nut it still will not come out. After some banging and levering it comes out. Any ideas?
