Dominik Pierog
Hello.
I have idea to show something really simple for beginners... and I little fail.
http://www.youtube.com/watch?v=RSle6bPPpwU
http://www.youtube.com/watch?v=O25xAtTib7M
I want customize it with scroll saw cut off wolf pattern > Free Scroll Saw Patterns by Arpop: 2 Wolves
For drill holes I use this....
This is trash. Exit hole is offset by a few mm from the entrance hole in pattern.
The battery in the camera is unloaded. Without warning, there is no indicator when it starts. Everything going bad.
In the meantime, I prepared a different project. I was able to finish it.
Fretwork coin maze.
Is made on laser cutter but I clean burns on the side surface. You see is clean plywood on each 9 layers
http://www.youtube.com/watch?v=jch8786ToPA
Maze solution
http://www.youtube.com/watch?v=MF4kzzTRiF8
In final wolfs looks ugly But this idea is preaty neat.
Check movie >>
https://www.youtube.com/watch?v=LQUP1aq ... .be&t=6m7s
https://www.youtube.com/watch?v=L_XSszmJQ6g
Fretwork coin maze.
Maze solution
Check movie >>
