CNC moving Z-axis during cut
Chris Puttick
20 Aug 2024
Just getting up to speed with CNC machines, only played with the laser so far and getting my head around gcode editing. Planning ahead, is there a way within gcode to tell the router to move up/down during a cut (creating curved reliefs). The software I'm using (UGS) doesn't make it clear if it's possible, and of course it may be the software can't - but should it possible in general? If so I'd be very grateful for some example gcode :)
NB I guess it may not be possible/practical with some CNC machines but I'm assuming a Z axis linear rail is being used for a reason
A very basic answer:
I think you may find that UGS will send and interpret the G code co-ordinates to the CNC Machine but is not generally used to create the G code, for example UGS will interpret the G code signals and move the CNC axis in the Y+, Y- direction Z+ Z- etc.
You need software to write the G code first called CAM software.
You send the G code written in cam software to UGS then UGS sends it to the CNC to create the required movement.
Vetric: https://www.vectric.com/ is CAM software.
Yes you can create movement on a 3 axis (X,Y,Z) CNC in all directions at the same time to create a dished effect etc.
If you download fusion 360 (free for hobby but nerfs the feeds and speeds of g code output) or a demo version of Vcarve pro or Aspire ( which will let you do everything except actually export gcode ) .
You can play around with genarating gcode and then watching a demo of what it will do when put into action using the preview modes. This will teach you a lot about how it works.
Having had a quick look at UGS, it looks to be very similar to CamBam which I've been using for my router. On the question of 3d operations involving the Z-axis, there are 2 options. Firstly, and I haven't ventured beyond this, there is 2.5d which is basically a number of 2d designs at varying levels in the Z direction. These levels must be specified when inputting your CAM criteria. UGS will automatically handle Z movements, ie, clearance heights and depths of cut, involved with 2d designs. You will need to input data for these.
How are obtaining/designing your input drawings? I use TurboCad and save my drawings in DXL format which CamBam can handle.
The second method is full 3d. In this case you will need a 3d design model saved in STL format.
I don't think you need to worry about g-code at this stage of your journey. The only times I have had to understand what's going on is when the machine software has identified a problem, eg, calling for a movement outside the machine's limits.
Brian
