CNC machine maker Recommendations
chessfoss
11 Jan 2021
Bedale
Hi,
I am based in North Yorkshire and wondered what machine makers people have experience of buying from and who you would recommend. I am buying to replace an existing cnc machine for my wood and slate sign business so it will get a fair bit of use. I need more than a ooznest workbee I suspect? I just don't want to buy something and find I need to replace it soon after. It'll probably be running for about 4 hours a day .
Suggest you try that question over at MYCNCUK.COM There are a good mix of hobbyists and pros on there, though the focus is often towards self build ( a rabbit hole you should probably avoid if you have a business).
Thanks for the suggestion.
