bilboburgler
Those ideas certainly chime with my thoughts. A drawing would be wonderful, thank you.
There endeth the good points.... I can't imagine what happens with a plunge cut.For similar space utilisation,there is no particular reason why you couldn't tip a conventional type of machine on it's side.The Maslow is an interesting concept. I looked at it some years ago as it's quite space efficient. That said, I don't think the accuracy is close to a "proper" CNC machine; so it's best suited for large sign cutting type work.
It's definitely one of those "brilliantly original idea, but does it actually work (well)?" kind of things isn't it.One of our Maker Space members made one of those and the bits are still in the cellar. He likes the technology, but....
I think ballscrew whip is unlikely to be an issue under most use cases, unless very long or very skinny. I remember reading some info about this ages ago.The idea of pre-tensioning the ballscrews to prevent whip is entirely sound and might be a good deal easier if the machine was designed to operate with fixed ballscrews and rotating ballnuts.If one of the users of the makerspace has the ability to 3D print toothed wheels it might be that they would last a good while and then when a 4th axis has been introduced,more durable replacements could be produced.The ability to make the parts to replace itself has always been an appealing aspect of a machine.The disadvantage of having to include power cables for the steppers in the drag chains to the gantry is a modest one,although one or other will already be holding the power cables to the Z axis.
I don't think pre-tension is really there to solve whirl, I think it is to solve Euler collapse or at least Euler bending when the compressed part of the longest part of the screw moves out of line. Tension stops that screw getting into Euler bending and, of course, as a secondary result, stops any whirl that is due to that.I think ballscrew whip is unlikely to be an issue under most use cases, unless very long or very skinny. I remember reading some info about this ages ago.
I did see a very interesting solution to it where about the centre of the length they put a plastic thing that held the centre true, it was a fairly simple fork shape that cradled the screw, the clever bit was that it popped out of the way when the ballnut passed by and sprung straight back to position.
I think just going up a size of screw is probably easier though.
Ollie
I don't think you need to think about pretension, I also think for the size of machine you said, I would go for 16mm ball screws and 20mm rails and then no matter what you want to cut it will be man enough to tackle it.I'm thinking of proposing to build just a Z axis as a demonstrator for the Space, it should let us see the beast, play with the axis motors and slide plus the software at a low cost. Plus it allows me to design something as light as possible with standard components. If no one shows any interest it allows me to focus on alternative projects for the Space.
that kit looks pretty good value for money.I only managed to read some of the posts, not the enire thread and, being in a similar situation with 'everything needs to come through the front door', I will share my journey. The CNC machine was on my bucket list and, after a lot of research, I chose the 1010 Workbee to be my machine of choice. At that time there were 3 popular versions: Ooznest for the UK market, Openbuilds for the American market and Bulkman 3D for the Asian market but all 3 selling everywhere. It was a hard choice. I mainly chose Openbuilds because of the proved and tested American quality. The UK was great, even improved, but the price difference from USD to GBP was pretty prohibitive for me. Bulkman's was cheaper but I was hesitant to make such a purchase from them. This was also 2019 and since then Bulkman built a name for themselves.
Out of nowwhere, in 2020 a Workbee dealer appeared in the Romanian market. I contacted them, stated my interest in buying the CNC and got no reply for a long time. Eventually I managed to find out that they didn't have the actual machines, they were distributing the CNC routers sold by a company from Portugal, by the name of RatRig. I also found out that RatRig were innovators experienced in 3D printing technology, a group of passionate people who added CNC machines to their portfolio. Not only added it but, after consulting with the community, added their own improvements.
After researching into it, I ordered their version of the 1010 WorkBee CNC. Soon after my purcahse, they launched their own design of a much improved version of the WorkBee, this time with linear raild and steel plates, called the KillerBee. I was annoyed for not knowing about it but it was my fault since I wasn't following their community at that time. After much consideration and saving the money required, I purchased the upgrade kit for my machine. Soon after my purchase and now owning a superb machine, they launched their Stronghold Pro CNC which is 100% their design, concept, integrating feedback from the community as well. It was again my fault because now, even if I was following their community, I had not paid attention to their updates...
This Stronghold Pro machine might be a good candidate for your needs in relation to the stated conditions. Might be worth checking it out. This is the link to their machines Routers - CNC Machines and here is the version I was referring to Rat Rig StrongHold PRO CNC - Standard Kit
They have a great customer support. And they also offer very solid tables and other accessories for the machines. Further, they have a helpful community where you can find all info you need before making a purchase decision.
Merry Christmas and happy holidays!
Brad
Thats nice rotary work, any tips on the programming for 4th axis. Do you use Vcarve pro? I had a look at it and it seems you have to do a flat pattern and wrap it somehow. But, if I start with square stock do I need to rough it into round first.I don't think you need to think about pretension, I also think for the size of machine you said, I would go for 16mm ball screws and 20mm rails and then no matter what you want to cut it will be man enough to tackle it.
12 mm ballscrews do not have much depth to hold the balls.
Here is an image of the extended Z axis when I was in the process of making it, I wanted to put a 4th axis on the bed to turn a 330 mm high stone disk and cut a relief shape around the circumference.
I have also cut gear teeth around a 280 mm clock wheel.
This is made with 20 mm linear rails 16 mm ballscrew and the ball nut is rotating at the top powered by a Nema 23 motor, I wanted to to get the least amount of overhang so no traveling ballnut.
The Z axis is pivoted so able to swing left or right around 20 deg it is also demount-able and able to be moved to the Stone cutting cnc then put back on the metal/wood cutting cnc.
2nd image showing when I was fitting it up on the metal cnc.
3rd image show some work cut into wood.
Yes you need to cut square to round on the 4th axis keeps it all true, to do something like the round bases you would start off making the 2 1/2D model you want to build with in my case i had made the shell for a set of drawers, I work in Vectric Aspire I created the layout for the wrap attached the models then produced the machining code.Thats nice rotary work, any tips on the programming for 4th axis. Do you use Vcarve pro? I had a look at it and it seems you have to do a flat pattern and wrap it somehow. But, if I start with square stock do I need to rough it into round first.
Ollie
Thanks, I have vcarve pro so I think its the same in general except I can`t model the 3d shapes directly in it. Do you set Z zero to the spindle centre?Yes you need to cut square to round on the 4th axis keeps it all true, to do something like the round bases you would start off making the 2 1/2D model you want to build with in my case i had made the shell for a set of drawers, I work in Vectric Aspire I created the layout for the wrap attached the models then produced the machining code.
The wood test pieces are 100 mm dia the layout was then increased to make 310 mm Portland stone bases to fit within a water feature.
Shell model:
layout:
Wrapped:
That's quite normal, no sooner do you commit to one, then sods law kicks in and the upgrade comes out.I only managed to read some of the posts, not the enire thread and, being in a similar situation with 'everything needs to come through the front door', I will share my journey. The CNC machine was on my bucket list and, after a lot of research, I chose the 1010 Workbee to be my machine of choice. At that time there were 3 popular versions: Ooznest for the UK market, Openbuilds for the American market and Bulkman 3D for the Asian market but all 3 selling everywhere. It was a hard choice. I mainly chose Openbuilds because of the proved and tested American quality. The UK was great, even improved, but the price difference from USD to GBP was pretty prohibitive for me. Bulkman's was cheaper but I was hesitant to make such a purchase from them. This was also 2019 and since then Bulkman built a name for themselves.
Brad
Yes Z zero centre, and me too sorry to take up part of thread.Do you set Z zero to the spindle centre?
Sorry, didn`t mean to hijack the thread.
Ollie
Your wish is our command, Amana have many different sizes of insert surfacing bits available, the most of any provider globally. Check the range out hereThanks for the recommendation. I will see what they have in the new year. I have a 1 and 1/8" Amana surfacing bit that I like a lot but replaceable inserts would be an additional blessing.
Based on that budget I would look at a Ratrig CNC or Openbuilds , I have both (in fact 3) but I prefer the Ratrig to Openbuilds although on my RR models I do use the BlackBox Controller from OB. Perhaps even think of a larger bed of 1metre by 1.5metre They are both very good machines, you can easily add to them if you want to in fact I have stiffened my latest RR machine to enable it to easily cope with Non ferrous metals and some mild steel work.I'm working in a Maker Space in West Yorkshire. In our 2024 budget we aim to have £3-3.5k set aside for a 3 or 4 axis cnc portal miller for wood cutting. Since we have multiple users of varying skill ranges we need a fair bit of rubustness built in and would like proper slideways and ballscrew drives. Assuming that extraction, bench and any shielding was covered by other budgets and we wanted to be able to cut at least a 750x750mm area what machine would you look at?
Onefinity
Shapeoke
Bulkman
any other
