craynerd
Good evening guys, I'm a hobby metal worker with clocks as my thing but I've been collecting wood working tools for the last year and improving my skills. I've been looking for a planer Thicknesser for a while but they are too pricy for me right now. Today I was excited to to pick up a Clarke CPT 1000 for £20!! - I knew it was "broke" but was hoping for the best. Anyway, I've got it but I'm not too sure! The motor works but on pulling off the side cover, it is missing the main drive pulley on the cutter bearing block and the belt. That would be fine and easy repairable, I could even possibly make my own pulley BUT it is also missing ALL the required gearing, pulleys and "stuff" for the auto feed on the Thicknesser to work!
I'm gutted :-(
The machine is £320 new. Bearing in mind I'm into metal work and can fabricate some of my own simple stuff. I can probably get the main cutter running for less than £10. However, can a Thicknesser be used, with care, manually pushing the material through with a push stick or is that not possible? Is it worth it just to get the planer on top working and ignore the Thicknesser? I have requested a parts cost list from Clarke but I expect there are so many parts missing to make the auto feed working, it won't be economical.
I can post pictures later but any initial thoughts as to whether this machine is worth fixing, bearing in mind I've only paid £20 for it or is it just worth scrapping?
I'll post pics soon and this will be a project log if I do decide to restore it. I just can't see making the auto feed work a possibility as there is so much missing.
Chris
I'm gutted :-(
Chris
