AJB Temple
Finely figured
Was using large hand held hilti 110v circular saw yesterday, a tool I am quite familiar with. I was doing parallel cuts in green oak to take 70mm deep tenon cheeks off a 9" post. Suddenly the saw stopped dead with a jolt. A chunk of oak had broken away from the beam and jammed the saw blade against the guard. This was the last cut of the day anyway.
(after unplugging the saw) I've removed the jammed piece and originally thought the blade was bent, but it appears to have sprung back into place once I took the jammed pice out.
In 30 years of woodworking such a thing has never happened to me before. This timber framing malarky puts you in close contact with some big tools.
I have not tried to restart the saw yet or checked properly if the blade is OK. Slightly unsure what precautions to take when checking it. Any advice?
