Hugo_Wolfwhistle":2ulur520 said:
Eric The Viking":2ulur520 said:
I like my Makita, but in the choice with a TS55, don't put too much store by the Makita kit having a second rail.
Thanks for the pros and cons list Eric, really helpful to get feedback from an owner. Just to check I understand your post correctly, are you saying that you don't think the 2nd 1.4m rail with the Makita would be much use to me (because of alignment issues), therefore the TS55 with 1x 1.4m rail at £315 is going to be just as useful as the Makita with 2x 1.4m rails + connectors for £300, and therefore the saws are really comparable price?
If so, are you suggesting that I would be better to buy either of them with 1x 1.4m rail, and then also buy a 3m rail as well?
I think that's what I'd do if I was buying again. The basic kits had a big price difference when I bought mine AND Makita had two rails and a bag as standard. So because I was buying on a tight budget there was no contest.
Now Festool have changed their channel marketing strategy (he said, politely), and their dealers discount more than they used to. Given that, I would seriously consider having just a TS55 and a single rail, and buying a long rail when I had need.
Why the Makita long rail? Basically, price. Last time I looked, the Makita 3m rail was less than half the Festool price.
You can do more with the Festool rails in terms of fitting accessories etc. The Makita saws have an anti-tipover feature for use when you're sawing a bevel cut (and It does work well). The TS55 can't use that*, BUT all the twiddly stuff you can do with a Festool rail, you wouldn't want to do with a 3m rail anyway (such as plunge distance stops, mainly used for sink cutouts in kitchen worktops).
I guess if you ever want to run a router on it then that's different, but otherwise, given both saws do the basic job well on both sets of rails, to me that's a no-brainer.
I get by when cutting 8ft boards lengthwise at the moment, but when you have to make a lot of repeat cuts (I was slicing up ply recently to fit through our small attic hatch to board it out), fiddling with a pair of guides is a right pain. If you're clumsy (and I am!) you risk bending either the guides or the joiner pieces, at which point it's expensively game over.
It wouldn't matter if you had Festool or Makita - once joined as a pair, they're a nuisance to move around together.
if I can find a 3m Festool rail for similar money to the 3m Makita, then should I get that instead?
What accessories don't work with the Makita rails?
I think I would, but I doubt Festool have halved the price. Go have a look in a Festool dealer: Axminster sell both incidentally, and (courtesy of a salesperson on a quiet Tuesday morning), I spent a happy half-hour playing with the Festool attachments to find out what fitted on which rails (the wife wasn't too happy, but she'd brought a novel in case, so I got away with it).
I don't think Axminster sell the 3m Makita rail (they have always had a limited subset of Makita accessories for their power tools), but my local Makita agent offered it to me recently for about 120 quid and no shipping charge - can't be bad.
Things that work the same on both:
- the saws' basic functions - straight cuts and bevelled straight cuts, and plunging (without distance stops along the rail).
- the mitre gauges (they're identical I think. I have the Makita one and it's pretty rubbish)
- The clamping system to clamp work under the rail (the track underneath for the F-clamps is identical.
- Both saws can do 'backwards' scoring cuts at 2mm depth for cleanly cutting faced boards.
Things that don't work the same:
- Anything that uses the Festool accessory T-track at the back of the rail. The Makita's isn't the same - it has a C shaped slot instead (for the anti-tipover thing), and the Festool distance stops, the accessory tracks at right angles, and anything like the router carrier probably won't fit on it. That said, the mitre gauge I think is the exception (see above - it's rubbish).
I'm making some bedroom wardrobes soon, probably in veneered MDF (if I do the carcases myself). I'll get the Makita 3m rail then, as otherwise doing a lot of 8ft cuts will simply be too awkward. It'll pay for itself quickly.
E.
*(guess you might mod it though, fairly easily)
