steadyeddie
Chuck key (screw type, not square type) to fit Axminster GK / SK 100 chuck. Thanks.
You can become a Supporting Member or just click here to donate.
I was hoping someone on here might have a 'spare' one for sale. I'll have look at the Axi website. Cheers.Have Axminster got one? Free P&P atm I believe.
I'm after one for a Clubman chuck ( key style similar to Jacobs chuck). I believe the square end is for the Evolution range. Cheers.Please could you say what you mean by "screw type". Having looked at Axminster's pictures of the chuck, they show a standard square-ended chuck key.
Are you looking for something special, that would not be supplied with the chuck by Axminster?
Cheers, appreciated.Axminster sale standard and long chuck keys. Screw type ... sounds like you are talking about the gear type and not the square drive
310426 is the Axminster part number for the standard size. 340017 is the number for the long version
Thank you, appreciate the info.I think the GK and SK in the item description are for 'geared key' and 'square key', which means that including the SK100 reference might be slightly misleading.
Now, having looked at the correct picture, the geared key is not like a standard Jacobs chuck key. This means that Axminster might be your only source of a new item.
Right now, their website is showing a 'save with used, like new' long key for £15.43 instead of the usual £18.16 or £14.98 short one.
Ongoing process. I'll probably add it to my xmas listHiya did you get sorted.
