RogerS
I'm trying to locate a supplier for this (32mm ideally) but I'm drawing a blank. Can anyone help please?
Roger
Roger
jasonB":wpanj9uv said:Roger if its just a straight run you could sleeve it with CP tube, Ironmongery Direct do a 40mm tube so that should take 32mm waste, bends may be a bit tight. I've used it in bathrooms before and not had problems with corrosion etc.
Other option is to do it in 35mm copper then get it chrome plated.
Re the RAK Sanitary ware, did you get the matching seat as most of them come with a form of "cavity fixing" that pushes in from the top, no wing nuts from underneath. A lot of bathstore stuff is/was ths make.
Jason
Mcluma":zcu2gro2 said:I also had lots of problems sourcing the 32mm in chrome plastic,
But there are some online european wholesalers who can supply you that
