Homeless Squirrel
Had a snout around on the Axminster Website came across a few vices that looked interesting!
Do have a 3" Engineers types and you can pivot work on it's end/side as has a lockable mech (so it up ends with handle up in air!)
Been looking at engineers vices like record/woden or similar and around 4" odd to 5 to 6" but only thing with 6" weighs a tonne!
I don't have a bench as such well kitchen worktop improvises! and a Keter folding up jobbie which is ok but unless i mod it? ends of legs are against wall but top isn't so if planing things a bit too enthusiastic can rock a bit so looking at making a plinth to fit end/side so force is held by that.
Made a huge bench hook out of thick plywood i use on top of Keter as good as it is at somethings trying to affix objects like vice/clamps etc isn't it's forte but does have two slots for there own clamps/end stops.
Going to mod bench hook so can move back stop forward/back and angled also and going to make another one to fit vice on out of thicker wood for weight and stability unless i stick on this one with bolts with wing nuts so can shift easily so prefer not to get a no6!
Axminster Workshop Vices Parrot Versatile Vice like this one but does sit high jaws open a decent amount and can place on it's side.
Or this one Axminster Professional All Purpose Engineer's Vice 125mm Do like the other jaws as do make/repair metal things inc repairing car bits! plus handy if threading bolts etc and cutting metal like tubes for making tripod rod rests!
https://www.axminstertools.com/axminster-trade-vices-all-purpose-engineer-s-vice-125mm-106191It is quite a bit lower than first one so less leverage if planing bits but weighs a lot more plus more cash!
