For regular chisels, as long as the steel is somewhat alright then I would be spending my money on some other tools that you need.
Don't bother buying a set if you already have some as they will hopefully do the same job,
just as long as they are not half the length they used to be, and get sharp.
As long as the handles are not loose...
As long as the handles are in line with the blade, be it cranked or not.
I have a Stanley set of 5 I think, and I only use two of them...these have cranked handles more suited for paring 90 precent of the time.
(one handle is loose in the set that I know of)
I use the same(ish) size narrow chisel but a Tesco brand for hitting, as the handle isn't cranked which transfers the force more than the cranked.
I don't use any of the other non cranked set.
Not saying that I would go out and find a non cranked chisel if I lost this one though.
What's wrong with the ones you have?
I am a bit sceptical of graduated sized handles being that desirable.
I was paring the walls of a mortise the other day and it was slipping about in me hands...
Was thinking I would have to get some hurley tape for the job.
That could mean the handles might be too thick...
I wouldn't have an issue grinding the handles on these ones if I really needed to.
Only put a big nick on my wide parer recently, honing on the edge of the stone, its tricky not to!
That might hurt if it were a fancy brand.
If I ever see the day where I were to use fancy stuff only, then I would need to get a better system for keeping my oilstones flat.
I aint keen on flattening them without a tool getting sharp in the process.
Surprised that I haven't seen someone try the possible solution that I'm thinking of...
An adjustable height oilstone :roll: :roll: :roll: :roll: :roll:
Proper faffery!
All the best
Tom
