Chestnut stains
stevebuk
23 Jan 2007
Nottinghamshire
hi
i am thinking of buying a sample pack of chestnut stains, does anyone here use them or can anyone say how many bowls or whatever this sample pack would do, or would it be better to buy the bigger bottles?
I have been offered the whole range of colours in larger tins for £30, would this be better.
I bought a pack recently. They go a long way, can't say how many bowls as I have been using them on smaller sycamore vases and things. They dry extremely quickly and I have been using paper towels which is not the best thing as it soaks the stain up too much. Certainly worth getting IMHO and playing with. If you have a pair of Marigolds wear them 'cos the stain stains whatever it touches. DAMHIK
pete
Hi Steve .. not sure if anyone else has used these.. but I've done one or two and used the 'foam type' paintbrushes.... they seemed to work well !
I diluted the stain with thinners 50/50 because the first couple of attempts ended up a wee bit 'cloggy' where the stuff had a chance to 'gather', all be it minute quantities.. but it showed when it dried.
The diluting stopped that happening and didn't seem to adversly affect the application by foambrush.
As Pete says, the paper towel route did the same for me.. it sucked up the towel and just got everywhere, except where it was meant to go !
I've got the dark blue and the red only ... but they turn out well.. especially when its a 'partial cover' against a nice pale wood like sycamore for example.
I quite like the stuff, in the 'right setting' ..... its a nice effect.
Good luck.. look forward to hearing how you go with it :D :D :D
The amount of stain in the little bottles in the sample pack does go a very long way. However, a full set of all 8 colours in the larger bottles for £30 is a good price when you consider that most places are selling the large bottles of stain now for at least a fiver a bottle. The stains don't seem to degrade in the bottle with keeping (they are celllulose based, so make sure you do the lids up tight in storage to prevent the solvent from evaporating.) If you plan to be using them on a lot of large objects, I definitely go for the large bottles at that price.
Not sure how many bowls each little bottle in the sample pack will do. I started off with a sample pack and I do remember that yellow was the first colour than ran out, mainly because my partner used most of it up colouring about 8 large tool handles (one of these was a felling axe and the others handles were only slightly smaller). I then managed to find the large bottles of all the colours except white in a sale at £2.95 each so bought one of each of these.
For lathe work, I usually apply the stain generously with a very soft brush (which wastes less stain than using a paper towel), then rub off any excess stain with a cloth. This method is also less messy than applying with a cloth and keeps the stain mostly off the fingers and on the wood! The stains do stain skin, but will scrub off with washing up liquid if you do it soon enough. Splashes on clothing are less easy to remove.
The stains are rather unforgiving and will highlight any blemishes or sanding scratches so you need to make sure the finish on your wood is first class before using them. On less-well finished wood (like my partners tool handles!) the colours were quite dark, but I've found them all to be much brighter and paler on well finished turned items. The darker colours (dark blue, black, purple & red) can go a bit patchy on end grain.
As the stains are cellulose based, be aware that they will bleed into any cellulose based finishes you apply over them (including Woodwax 22) - which could be problematic if you you are using several colours on the same piece and (like me) don't want to use spray finishes over the stains.
They are certainly fun to use and open up all sorts of creative possibilities.
tekno.mage
I have the sample pack for a while now and a small fingertip amount goes a long way. I started mixing mine with sanding sealer, seems go on easier - doen't dry as fast so you dont get immediate rings.
Washes of the fingers easy enough.
30 quid for the whole range is crazy cheap - My supplier here wants 8 euros a tin ! - I paid 15 euros for the sample pack.
- as stated above and in other threads, you need the best finish ever, then look at it again before you add stain ! as everything shows up otherwise.
Loz
Hi Steve I have not used the Chestnut stains on large items. I find it is quite heavy colour if you do not dilute as the others have said. I have used however water based dye. I find this covers well especialy if you wet the surface before applying.
Go with the larger set for £30 sounds like a bargain. In fact is there more than one set ? ;)
Is that all 9 from the rainbow pack in 250mls Steve?
Sounds a bargain, as that's a good £50 quids worth, if you'll use them of course.
I'll go halves if you fancy? I don't mind filling a few jars.....
