Interesting. The reviews for the TS250 on their site arent as good as the reviews for the TS200MikeJhn":1gob8bli said:This Axminster fence has had a couple of good reviews on here: http://www.axminster.co.uk/axminster-ri ... ade-100205 personally I don't like a fence that does not have positioning locks on both ends.
The Axminster TS250 has a much better fence than the TS200, whith the extended table and fence guides.
Mike
I have the TS200 mk1 (bought just before the mk2 came out) the fence on this can be modified to give decent repeatability and stability (tapping threads/holes into the clamp and inserting nylon bolts for free sliding, filing down the clamp so that it sits level etc.)evidence":30wlejjk said:Does anyone know which table saw has the better fence, the Axminster TS-200-2 or the Charnwood W619? Or does anyone know if there are any aftermarket fences for these saws?
MikeJhn":158914pq said:Most of the gripes seem to be about dust extraction, there is a thread on here somewhere about the modifications needed on the TS200 to make it more efficient to extract dust, as the TS250 is near identical I can only assume the same mod's need to be carried out to ensure efficient extraction.
Mike
For me that's still not an improvement as there is nothing to lock it down at the other side. The one I saw still has some issues in that it was hard to move it in small increments and lock it down in the same place.MikeJhn":32hfkhja said:MikeJhn":32hfkhja said:Most of the gripes seem to be about dust extraction, there is a thread on here somewhere about the modifications needed on the TS200 to make it more efficient to extract dust, as the TS250 is near identical I can only assume the same mod's need to be carried out to ensure efficient extraction.
Mike
Visited Axminster Sittingbourne two days ago and in the demonstration area they had a TS250 fitted with one of these underneath it: http://www.axminster.co.uk/big-mouth-dust-hood-200114 they had also taped up the gap between the base and fixing rails.
The TS200 they had on display had a full length fence that had a bearing on the far side of the table that tightened against the table when you pulled the fence lever down, gave a much better rigid fence.
Mike
Yeah, there a quite a few. The Bosh and Dewalt site style ones do, and there are a few other cabinet saws that do as well.MattRoberts":16rf3cbu said:My axminster AW10BSB2 fence locks on both sides..
MikeJhn":3uuyp7iq said:Sorry for the thread drift, but it is how we find out about other systems.
Matt
I think you have miss-understood, on the Triton work centre you physically have to move a lock at both ends of the fence, setting to the desired dimension from the blade on both ends, not rely on an shortening of the lever mechanism to pull the two ends together taking a reference from one end only.
Mike
pike":qicj6px0 said:I know this is months old but as I've been considering a TS250M-2..
Bodgers. To clarify, do you know that the TS250M-2 basic has a fence which does not fix in any way on the far end of the table, however, as Mike has explained to me and I've checked in the docs, the RH extension table comes with a different fence which has a bearing on the far end. So when clamped down it grabs against the far end, giving it more stability.
I used to have a triton workcentre which literally could be locked both ends. The TS250M-2 full length fence provided with the extension table doesn't actually lock at the far end, but it does have a guide there which pullls tight when you clamp the fence on the near side.
My "problem" is I don't really want the extension table but it seems I might have to, to get the better fence. I really don't like a fence which is completely free at the far end.
Cheers,
Carl.
