charnwood planer
kazant
27 Apr 2016
colchester
my planer thicknesser has a slight problem i need help with please the thicknesser is ok but the planer is causing what i think is referred to as snipe on the end of the wood, it was ok until i had it moved to my new shed/mancave. so i am thinking its the bed out of alignment (hopefully) anyone else had this problem and how can i fix it. thanks
Is the out feed table lower than the cutter knives at their highest point? Get a piece of planed timber and place it on the bed overlapping the cutter block. Keep raising the bed in small increments until the timber doesn't get pulled forward when you rotate the cutter block by hand. Obviously please undertake all the adjustments with the machine isolated or unplugged
many thanks was easy fix following your tips.
