Changing door hardware
As suggested by Woody Alan I would certainly avoid those tubular latches, they tend to be rubbish.
If you can find some square bodied ones with the same backset as the old stuff then all you need to do is pack out any size difference with some blocks of wood glued in.
For the hinges if re doing a door for whatever reason, I try to find hinges with a different hole drilling pattern, this way you dont need to fill the holes in.
So if 3 inch hinges were in there get 4 inch and use the tops or bottoms of the existing mortices to line them up, or if using the same size I find that different manufacturers use different patterns or if you go for grade 14 thrust bearing ( my favourite but not cheap ) they will have a different drilling to the same size traditional washer style.
Beware leaf thickness if they had cast iron ones before they are super thick compared to modern stuff.
Ollie
Very good tip and yes previous hinges were the thick iron ones so will need to adjust appropriately
I've found that the slats from a modern wooden Venetian blind are of a thickness that makes them very useful when needing to cover unwanted latch and hinge mortices.
I may have a perfect Edwardian alternative.... Got loads of lats from when the ceilings were removed. Potentially a bit thick but could always slightly open up the old hinge recess to accommodate
Be prepared for doors moving after they come back from striping, always keep them closed for a while to stop any twist.
If the doors have been dipped to strip then you need to hang them soon as possible and keep them closed as much as you can until acclimatised.
We lived in a Victorian house until 3 years ago. The internal doors had all been stripped and waxed. They looked hideous, and the door stops had all been removed and refitted at crazy angles to accommodate the now twisted doors. I agree with Phil P. on this. Just don't do it, you're likely to expose all sorts of repairs, filler, shoddy joinery.
If you don't replace the edwardian locks on the main interior doors you will have the same 2 problems as edwardian gentlement did all those years ago:
  • Household serving staff accessing the dining room at night and swigging the port
  • Your wife bursting into the living room just as you mistress begins to unlace her bodice
It was built that way for a reason - I would keep it original :)
Sadly too late, its with the door stripping company as we speak. I'm treating it as a relatively "cheap" experiment given it was £50 to strip or £200+ for new ie if I need to write off a few hundred quid on a failed plan, it's doable
I must confess we were perplexed why all the doors opened the "wrong" way until we realised that it was literally for those reasons, servants can knock and open the door without seeing anyone in the room they shouldn't
