Chamfer router bit
Mjward
UKW Supporter
18 Jan 2022
Yorkshire
Up to now I've only used a roundover bit to soften edges and that's been fine for bedroom furniture which gets touched etc.
But I'm now in the market for a chamfer bit as think it gives a slightly more formal finish (for bookcases).
However, I would appreciate some guidance on dimensionally what size would be appropriate. Will mostly be used on c40mm wide face frame/edge banding.
I was thinking the smallest one but have no experience here
TIA
I would be tempted by T916B with either the 1/4" or 1/2" shank just based on the fact you can do a small chamfer with a large cutter but you can't do a large chamfer with a small cutter should the need arise.
I like your logic Doug. Most likely will go the 1/4 route so I can use with the palm router once face frame is up and running but I've also got a 1/4 (and 1/2) collett on the table router should need arise.
I'm also toying with the idea of a **** bead which I guess introduces formality to a roundover. The kitchen units have a **** bead so would possibly tie in the joinery.
Actually think I've talked myself into buying both 😂
I have one or two that came out of these sets of assorted cutters that I generally don't recommend. They are both 1/4 shank and 20 or 25mm long on the diagonal cutting edge. They work great even though most chamfers I ever cut are only a mm or two wide.
Another option on rectilinear stuff with a palm router is to use the tilting base and a straight bit.
In conjunction with a guide rail and some edge stops, you can have alternate angles to the standard 45 degrees.
Ah missed these latest posts, will have to add more bearings to my next order. Went for the edge bead AND chamfer bits as both will be of future use and gives me a chance to have a play around to see which finish I prefer on this particular project
