Knot Competent
OK, this isn't exactly woodworking, but I know many of you have broader experience than just with the one material, and I have no metalwork experience at all (apart from bending the odd car or two!).
I need to make a door and frame from either extruded aluminium or PVC for the front of a glassfibre chameleon cage. I expect to use 25mm x 25mm or similar box section, total door size about 30" x 25". I'd prefer to cut lengths of tube and join them with corner pieces, but I've been told that if I mitre the corners I could silver-solder the joints.
Does anyone know of a supplier of tube and fittings, and can anyone offer any advice please?
Regards, John. Definitely Knot Competent in this field!
