Kidneycutter
Need to repair a chair. The leg has broken at the castor - the is still intact. WD thinking of cutting the shoulder flush and dowelling a new block on.
Ok sorry, should have proof read before posting. It's an arm chair with square shaped castors and the lag has broken right below the shoulder of the castor seat.not following the details. what is still intact? armchair / dining chair? maybe pictures if you can
is the point of the diagonal cut just to give more surface area for the glue?An easier way is to cut 5" or 6"diagonally from the bottom to the opposite side and glue on a new piece of wood so you can shape the bottom to match the castor. Problem with that method is matching the wood/grain and having to refinish the leg, if not the entire chair.
I would have though a half lap would give more support
Yes. Dowels make weak points.so with the long splice its all glue, no dowels or similar?
Thanks for the replies. My other thought was to turn a block on the lathe so the dowel was part of the block or would this create a weak point?
I'm obviously wrong, but I would have said that with a diagonal cut, all of the weight in the seat would just drive the joint apart, with the lap joint the weight in the seat is pushing wood together. I'm genuinely suprised that glue is strong enough for the strain. I'm assuming were talking just a quality pva based woodlue, titebond 2 or whatever?Yes. Dowels make weak points.
Have to be a well made joint - long for good glue area, close fitting dead flat surfaces slightly roughened with light pass of sandpaper, glue spread thick on BOTH surfaces, clamped nicely - and end to end to stop them sliding apart. The stuck in part to be well over size and planed down to match existing.I'm obviously wrong, but I would have said that with a diagonal cut, all of the weight in the seat would just drive the joint apart, with the lap joint the weight in the seat is pushing wood together. I'm genuinely suprised that glue is strong enough for the strain. I'm assuming were talking just a quality pva based woodlue, titebond 2 or whatever?
