I’ve recently bought a new house in which the central heating has me stumped. Some of the radiators arn’t working properly possibly due to an air bubble or something else?. I don’t understand how it’s been plumbed and would welcome any insights.
This is the system in the plant room.
Valve A is closed
Valve B is open
1,2,3 Zone control valves are for Downstairs, Upstairs and hot water tank respectively.
4 is a Vortex Z152 timed pump for circulating hot water out of the tank I believe through the system so that the hot water taps run hot quickly.
I’ve put arrows to show what I believe is the flow of water
Pump C pushes the heated hot water towards the three zone control valves.
Pump D seems to be pump on the return, it looks to have two pipes feeding into it as well as a connection to the heated water flow which is cut off by valve A
Upstairs is all radiators, whilst downstairs is radiators and a single manifold feeding an underfloor heating system.
All of the radiators have temperature control valves on them, some on the outflow rather than the inflow which I think are likely to be forced closed by the water flow and need moving so the flow through them is the correct way…..is this idea correct?
Having two pumps one on the outfeed and the other on the return smells like the the installer got the pump sized wrong, and tried to create a greater head / flow by doubling up the pumps? Is there another reason for adding two pumps?
I can’t think why there would be two returns to pump B, should Valve B be open or closed? Why have a shut off on only one leg?
Why would you have a connection through valve A?
The return from the hot water tank heating coil seems to go into the flow side of the upstairs radiators after the zone control valve, is this normal rather than returning to the boiler?
Valve A is closed
Valve B is open
