correct, There are quite a few brands using either 24v or 48v, designed to run off POE (its a pain there are two standards)This is because it is designed to run on PoE - most likely configured to operate at IEEE 802.3at which is 44-53v (48v nominal) 30W per port. This is the benefit on using PoE for runs up to 300m as it uses the spare pairs of cables in the CAT5/6 cable.
Using a 48v buck/driver from a 12-24v backup battery and a solar panel will allow you to run a LR wifi link from one of the usual suspects as they don’t have a significant power draw. You can set up a wifi repeater, PoE router and camera all on the same setup and it’s pretty seamless.
