Carrom or Indian billards.
Jonzjob
19 Mar 2007
Ex nr Carcassonne, France. Now Corston Malmesbury
Specially for you Bodrighy, rather than carry on the hyjack of another thread here's my carrom board. The base is 18mm ply with a playing surface of 29".
The frame is iroko, horrible stuff to work, but ideal for this. The corners are African iron wood with box stringers. The corners are very slightly tapered so as to fit completly snug and the slots for the stringers were carefully cut after the corners were fitted. I was given the frame by a veru good French friend and it was mostly cut to size. Apart, that is, from the fact that the corners were not quite 45 deg but close enough to be a real swine to adjust!
The base was sanded very carefully and the markings drawn lightly on. The black is Indian ink and the colours are acrylic paints. Be careful to make sure that the paint is not too thick or it will form ridges on the surface. Then celulose sanding sealed and deknibbed. 2 coats of Danish oil, deknibbed between and then waxed with a furniture polish.
The rules for the game can be found http://www.carromcentre.co.uk/rules.htm. The rules change for diferent parts of the world. For instance in England the surface must be waxed, buthere in France it can be powdered..
The official board specification as as follows. Sorry it's a bit long, but??
A.1 Playing Surface
The playing surface of the Carrom Board should be of plywood or of any other wood equally smooth and be of not less than 8 mm in thickness and of a minimum of 73.50 cm and a maximum of 74 cm square with its surface completely smooth. A Carrom Board shall be able to have at least three and a half runs of a normally smooth Striker of 15 gms weight, when struck with the maximum force, from one of the Bale lines, to the opposite frame of the Carrom Board.
A.2 Frames
Adjoining the playing surface aof the Carrom Board there shall be wooden frames with inside curved corners made of Rosewood or any other hard wood with goo resistance, with a minimum height of 1.90 cm and a maximum of 2.54 cm from the playing surface. The breadth of the frame shall be not less than 6.35 cm and not more than 7.60 cm. Suitable bracings shall be provided underneath the playing surface and fastened with the frame.
A.3 Pockets
The pockets of the four corners of the Carrom Board shall be round inwardly and not outwardly and be of 4.45 cm in diameter with admissible variation of not more than 0.15 cm. The piece of plywood adjoining the corners of the frame shall be cut off.
A.4 Base Lines
a. Two straight lines of 47 cm in length with admissible variation of 0.30 cm equally distributed on all sides, black in colour, shall be drawn on each of the four sides of the playing surface, parallel to the frame on each side. The lower of these two lines, which shall be between 0.50 cm and 0.65 cm thickness, shall be 10.15 cm away from the frame and the other one 3.18 cm away from the lower part of the Base line b. The Base lines shall be closed by circles of 3.18 cm in diameter at either end. Within this circle a portion 2.54 cm in diameter shall be coloured red. These circles shall be called Base circles. These shall be drawn so as to touch both the Base lines and also the upper Base lines of the adjacent side when imaginably extended. The distance between the Base circle on one side and that of the other may be 1.27 cm approximately.
A.5 Arrows
Four Arrows, black in colour, of not more than 0.15 cm thickness shall be drawn at each corner of the Carrom Board at an angle of 45 degrees to any of the adjacent sides and each of them shall pass through the gap between the two Base circles and point towards the centre of the picket leaving a clear distance of 5.00 cm from the edge of the pocket. The length of the arrow shall not exceed 25.70 cm. A decorative arch of 6.35 cm in diameter with a pointer at both ends, drawn at the starting point of the arrows leading towards the pocket is permissible.
A.6 Centre Circle
Exactly in the centre of the Carrom Board there shall be a circle of 3.18 cm in diameter drawn black in colour with admissible variation of 0.16 cm. It shall be called the Centre Circle and shall be coloured in red.
A.7 Outer Circle
A circle of 17.00 cm in diameter with the centre point of the Carrom Board as its centre shall be drawn black in colour with an admissible variation of 0.30 cm. It shall be called the Outer Circle. Any decorative design in this circle is permissible.
