RobertMP
I could have posed this in my WIP thread but as it is a general question too I thought I'd put it in a new thread...
My sideboard has a lot of 6mm veneered MDF panels held by rebates in the surrounding frames. Doors and back/sides are constructed this way.
Repeating one of the pictures...
Two questions....
Should I put any glue at all on the panel when I glue up the frame? Let a bit bleed onto the corners or take care to avoid it?
And finishing... I won't be able to sand the panel near the edge once assembled (or the inside edge of the frame should that matter) so should I sand lightly, apply cellulose sanding sealer, sand lightly again then assemble - or what?
I've already applied sanding sealer to the top and left it while I make more parts. Plan was to get smooth surfaces with sanding sealer then finish everything with satin polyurethane.
Suggestions and better ideas welcome
Plenty still to do so no rush!
Two questions....
