In the toilets at work the hand towel roll dispenser has jammed and there are no signs of it being repaired. As a result I’ve decided to make a holder.
The simplest construction will involve a couple of arms at right angles to the wall. Notches in the end would accept the dowel which passes through the central cardboard tube of the roll.
However, another design occurs to me which, while being a bit more of a challenge to build, would IMO look better. This would also involve arms coming out from the wall but instead of being notched they would have what I suppose would be called „stub dowels“ on their inner surfaces. This leads to the difficult bit: it won’t work with fixed arms. That made me wonder if there is such a thing as a sprung hinge which would enable, say the last quarter of the arm to be deflected to one side for mounting/dismounting of roll with the spring pushing the arm back into place.
I’ve seen such hinges on small mechanical objects. I was wondering if a similar sprung hinges exist which are suitable for woodworking.
