I need to cut some aluminium plate for a full scale CNC machine that I am building and I have a fair bit of aluminium to cut - both plate and extrusion. I know very little about metal work, I was hoping that with the right blade, I could speed things up by running it through my Axminster Hobby Series HBS250N Bandsaw (http://www.axminster.co.uk/axminster-ho ... 0n-bandsaw)
I had heard that it's ok to do providing the speed is as slow as possible (mine only has 2: 600 or 960m/minute) and to use a course blade to prevent the aluminium melting to the blade's teeth. I dont want to destroy my bandsaw and yet I have too much to cut by hand so I am kind of nervous to just launch in. Any advice or experiences you can share would be appreciated such as do I need a special metal cutting blade? Can I also cut thin plate steel? Do I need a lube any kind of lube (language Timothy) etc?
