That's one of the advantages of the brackets that I linked to.....Its adjustable up/down and the inclination of the pin.i'd be worried of getting the threaded rob absolutely horizontal and level
Good point Mark.Not just the weight of the Ash shelf to consider but all the stuff put on it as well.
These brackets are the right thing for the job - I have used them for various things (from Hafele). You need to cut out a little housing for the main bracket part and otherwise a reasonably accurate 12mm hole (you can knock up a jig if you don’t have a suitable drill guide).That's one of the advantages of the brackets that I linked to.....Its adjustable up/down and the inclination of the pin.
Be aware though of the weight of your Ash shelf....
These are the type that I use......Suitable up to a maximum of 300mm deep shelf.
On a shelf the size you mentioned, I would use at least 3.....45MM solid Ash is quite heavy!
https://www.sdslondon.co.uk/concealed-floating-shelf-bracket-length-112-mm-diameter-12-mm.html
These are the Hafele ones I have used successfully - you can see all the details Concealed Shelf Support, for Installation into Woodwork or Masonry Walls - Häfele U.K. ShopI got some of these specific ones. I don’t see any flats on them though. There’s a light knurling at the rod base but it doesn’t turn. There’s a plastic type of cam on the base which I guess
Is for adjustment along with two set screws. How are these best installed? I guess I need to glue the rods in too as I can’t see what stops the shelf coming horizontally off the wall
When I did a similar job for my daughter I carefully made a jig to ensure the correct pin spacing and to help getting the pins horizontal and level. Ended up with the right spacing but all the pins sloped downwards! What to do? I ended up using the BF&I method i.e. a big hammer and tapped them up to horizontal again. It's still there some 10 years later.i'd be worried of getting the threaded rob absolutely horizontal and level
I expected something more “solid” especially given the published load ratingsI'm a bit confused Prizen....You say it's not solid and flexes?...With all due respect, what did you expect ?
A 10000mm wide x 300mm deep x 45mm thick shelf has a lot of weight & mass. The leverage from front to back is high, so if you wiggle them, of course there is likely to be movement.....The pins are only 104mm long! This type of bracket is not designed for you to be able to hang off the shelf and why would you or anyone else want to wiggle it about?
How many of the brackets did you use on this shelf?
Just how snug was the fit of the brackets in the holes you drilled? ( I make mine so that I have to use a mallet to knock the shelf into position against the wall).
Did you make sure you have tensioned the pin against the stop? ( If the pin is inclined slightly upwards before you slide the shelf into position, this will help to compensate for the natural sag due to the weight of the shelf itself)
