Scottdimelow
Hi boys and girls, thought I may as well share my ongoing project as I've not posted much on here.
I'm currently converting a Transit Luton into a camper/motor home.
I recently finished the interior insulation and ply lining, so I'm on to fixtures and fittings.
I'm building simple face frame cabinets, mainly to reduce overall timber usage to keep the weight down. I'm using redwood as I intend to either paint or stain.
I started by fixing a batten to the wall which the sink/hob will fix onto. I then made up the frame for the full height cupboard.
I simply glued all joints, then added 1 screw for each to hold in position. I then propped them in place and squared up.
If you'd like to see other aspects of the conversion I'm blogging it at www.myhousecanmove.com
