Hello All,
I've finally acquired a decent table saw, a Startrite 275 and have a few questions for anyone familiar with it.
1. It was originally a 3-Phase model but at some point been fitted with a rather weak 0.55Kw (3/4HP?) single phase motor. I will be fitting a bigger motor but i'm not sure that the pulleys fitted are original. It has a 100mm double V pulley on the bottom and a 60mm Pulley on the top. The current motor is 1425 RPM, is that right? or should I be looking for a 4-pole motor?
At the moment the bottom pulley fouls the door with the blade set low, I can hopefully shorten the belts a bit but it still seems a little large.
What's the ideal RPM for a modern TCT saw blade?
2. Are all of the fastenings BSF? They are definitely not metric and the saw has an imperial scale. I think it's probably 25+ years old at least. I need to find some new CS screws for the top and side of the fence, the mitre gauge, and the blade plate adjustment screws in the corner of the opening (see pic)
3. I've found the adjustment for the max depth but am wondering if there are any other adjustments? There's a ring with a grub screw on the tilt handle, is that my 90 degree stop adjustment?
If anyone had a scan of the manual it would be a great help.
Can anyone shed any light?
Tommy.
Tommy.
