I've a problem that I've just never got around to sorting, and im about to make a go of(if it is in fact possible) There is parts welded onto the frame for the bolts to screw into, worst case scenario is i would have to forgo those, and drill and countersink new holes and use a nut,bolt and spring washer to secure the top to the base.*
*I actually think this is going to have to be the way it is done. Depends if i can easily remove those bolt 'keepers' though i fear they are welded in place.
Right. Many moons ago I got my saw bench from Axminster outlet, a customer return, which had the problem of someone in the factory where it was built screwed up big time and made the drilling for the cast top to the lower base squint.
What this means in real time is the top is put on squint, so if i measure on the left hand side at the back, the table overhangs at the back by about 1mm but at the front edge of the left hand side it overhangs by about 5mm.
So what happens is the saw cannot be adjusted so the blade is parallel to the slots. I can adjust it slightly, but for example if i make the blade parallel to the slots at 90 degrees, when i cant the saw over to 45 degrees, the leading edge of the blade impacts into the table.
But if it adjust it so 45d and 90d clear the table, it isnt lined up with either the slots or the fence, so for the last several years I've been stuck with it adjusted so i can only have it at 90 degrees. This is not ideal, I mean 45d etc etc is part of the function.
Now I think if i remove the top, and re-drill the lower frame, or even cut it to give a bit of play, I can then adjust the top so it is square to the lower frame, tighten up the bolts and the saw will then be parallel to the slots, fence for 90d,45d and every angle in between.
So what i need someone to do is measure the left hand side overhang to tell me what it should properly be. Im guessing probably 2 or 3mm front and back.
The saw is the earlier 'hobby' model - red and white paint job.
This one
I've got all the bits - the right hand extension, the sliding table and it's a good saw, certainly good enough for my home use, but I'd rather it was all correct. I was thinking of selling it, mainly brought about by the fact i couldn't cut anything other than 90 degrees, but if I can square it all up, then theres no reason to sell. A big bandsaw and my plunge saw are useful, but some jobs really are only suitable for a saw bench.
This one
