Calculations!!
mailee
26 Jun 2005
grimsby Humberside
Can anyone tell me how to convert cubic meters or feet into linear meters or feet. I am going nuts trying to get it. Why can't timber merchants use plain language so we can all understand it?? :evil:
You need to know how wide and thick your stock is before you can convert it into linear measurements - and that's why they use it, because it is universal across all different timber sizes.
There are 144 linear feet of 1" x 1" in a cubic foot (imagine building a stack of 12" long lengths of 1" x 1"- to get that stack to be a cubic foot, you'd need 12 lengths in each layer to make it 12" wide, and 12 layers to make it 12" high), but only 8 linear feet of 6" x 3" (two 1 foot lengths per layer, 4 layers).
volume = length x cross section (bxh)
so
length = volume/cross section
1 cu ft (12 x 12 x 12) as 6 x 1 = 1/(0.5 x 0.833) = 24 linear ft
easier in inches (1 cu ft = 1728 cu in)
1 cu ft as 6 x 1 = 1728/(6 x 1) = 288 in = 24 linear ft
Hope this helps?
Brian
Hi Mailee
If you use google it has a great feature (calc). In the search box if you put for example:
12 inches x 13 feet x 1.5 inches in cubic feet
and hit enter
the result is shown!
You can also mix measures for example:
300mm x 2400mm x 25mm in cubic feet
or
3.5 inches x 300mm x 1 yard in cubic metres
etc etc
try it and see
(It also does weights and temperatures (be careful about imperial and american measures though) and lots of other stuff)
HTH
I know exactly what you mean Mailee, it does your head in!
My solution is this;
I buy mainly 1" timber. It normally comes in 8' lengths. On average it is about 6" wide.
Therefore each plank is approx one third of a cubic foot - work it out!
If you keep this in mind when buying timber it makes life much easier. For instance, if American Oak is £25.50 per cubic ft +VAT that works out at £30 per cubic ft. So an average plank costs you a tenner!
In the back of my mind I always have these prices currently;
Oak
Sapele
Ash
Beech £10 per plank
Maple
Walnut
Cherry £15 per plank
It's very rough and very approximate, but it works!
Dan
Thanks for that Dan, I shall bear that in mind. I can't understand it either if I had wanted to be a mathematician I would have taken a different interest but I am more interested in creating things in wood. :roll:
