Buying Advice - New Table Saw and New Planer Thicknesser
Prizen
19 Feb 2013
Dublin
Hi Guys,
After looking at purchasing a used table saw and used planer / jointer, I have decided that I will buy both new.
I just do not like the idea of risking buying a lemon with no comeback.
I will be using it for lots of small projects such as bookshelves, coffee tables, cabinets etc.
So my budget is £600-900 for each. What would you recommend I buy?
I'm sure Woodbloke will be along to recommend the charnwood w650
http://www.charnwood.net/shop/product/1 ... saw?cid=22
A good saw by all accounts.
If you can live with lifting tables to thickness. This or the axminster version are supposed to be good.
http://www.charnwood.net/shop/product/c ... r-1?cid=19
Or if you have the space? and want a separate planer and thicknesser
I have had this for over 7 yrs
http://www.axminster.co.uk/axminster-ax ... rod370404/
Excellent machine for the money.
And i have the original version of this ( 6yrs now)
http://www.axminster.co.uk/axminster-tr ... prod21831/
Can't fault it apart from being a brush motor.
This jet is cheaper and with the ct150 will be within budget
http://www.axminster.co.uk/jet-jet-jwp- ... rod365273/
thanks, how about record power offerings in comparison to these? Reason I ask is that Axi machines my be expensive to ship over to Ireland!
Not sure on the record machines, however i just checked out their P/T and the basic one looks exactly like the charnwood/ axi version. Only £100 more expensive. It might be worth chatting with axi to see exactly what the shipping costs will be :)
I would recommend a second hand Sedgwick TA350 with sliding table. Superb machine, solid and dependable with a good fence.
For a Little less money a Startrite with a sliding table is great.
Spares for both are readily available and there very little to go wrong. I have used both for cutting 4" inch seasoned English Oak. The Sedgwick has a more gutsy motor and would be my preferred choice.
If you can wait until summer, you tend to find a really good Sedgwick will fit into your budget. The Startrite can be picked up on eBay for circa £400. Check it has all of the extending bars, there should be five in total. One for the sliding table and two for the left hand table support.
I'm also looking for a new table saw, I was wondering what conclusion you might have reached?
I recently bought an AW10BSB2 saw without the table side extentions due to limited space, and an AW106PT2 planer thicknesser from Axminster. Both are within your price range. So far I am very pleased with them. They are very heavy machines - the threshold to my shed is 12" above the path level so I put them on trollies and with a long timber ramp I pulled them into place.
Good luck,
I would recommend one of the following, they are all second hand and should fit your budget.
Sedgwick TS350 second as previously mentioned. Solid dependable, and will last a life time
Dominion
Wadkin AGS10, this will take a 12" blade, see Daltons for a manual.
Startrite DS275. A lit of people under rate this machine, this is the one I have and it cuts 4" seasoned oak all day long.
I would also agree with the earlier note, that a sliding table is a very worth while.
Most modern planner thicknesses in your price band have been made to a price, and I would avoid like the dreaded plague.
Again, look at a 10" Sedgwick, Dominion or Wadkin. They will be machines that will outlast you and will stay flat and true and properly set up.
I bought a brand new Sedgwich P/T a few years ago. After a long frustrating time trying to get it to keep a setting where the planner tables would keep flat and true, I finally had to resort to the small claims court to get my money back.
