Yesterday I wrote a new thread regarding a "bargain" external SSD I had found on Amazon Just found this
Update:- All worked well for a few hours and I attempted to register it, firstly the utility pack that comes with it (bundled) did not and would not install, this is needed to get the serial number required for registration. To get around this I downloaded the bundle direct from WD and tried to register it, I did not hold out too much hope of being able to due to it being a "used" item, however WD did not even recognise the serial number let alone it being pre - registered.
Just after that it stopped working for a while then started sporadically, One of the things available on the WD "bundle" is a disc checker, it actually has 3 tests check 1 lasts a few seconds and I got a green tick ( whoopiedoo) the second test last appx 2 minutes, after 30 minutes the drive had crashed and was fully unresponsive. Test 3 was a full test and was to take between 2 to 3 hours to complete, after 20 or so minutes it stopped the test and left a message in red saying "This drive has failed the test"
I then tried moving everything back onto my main computer and had problems doing that cleanly but managed it in the end (I hope). Whilst checking the serial number of the drive I did notice that the firmware was dated 2005, I don't know if that bares any importance or not but in all honesty I did expect the firmware to be of a nearer date than that. Amazon have been fine about it all and have arranged for Hermes to collect it tomorrow when they will issue a refund back onto my gift cards (my original payment method) and I shall then order a new version and keep my fingers crossed that all is fine.
I may have just been unlucky in the one I had and others from the same seller may be fine to use, but too many red flags have been raised for me to take that risk, I am not going to slag off the seller due to the fact that this may be an isolated incident but I will advise caution if you are thinking of buying one, the one you get may run perfectly and I hope it does, Sometimes bargains are only for the lucky people in life.
Gary
Gary
