TobyB
After reading around a bit, I splashed out on the Veritas burnisher. I'd previously got reasonable results with conventional scraping with them sharpened on the ProEdge. Sometimes tearout - but OK. Never that successful with shear scraping. But useful tools for flattening bowl bottoms and recovering from ripple bowls where the gouge has been bouncing off a dense section ...
Just had a play on a roughed-out bowl and an end-grain log. MUCH better finish on both. Most striking difference is that I am producing real shavings ... long things 5+ cms or better. Can do quite thick shavings like I get off a bowl gouge, and terribly fine thin things that look like the ones people show when they are demonstrating how sharp they have their hand plane. Never see that off my scrapers before - dust and splinters would be the usual product. But the finish is really good too on the inside and outside of the bowl (never normally go there with a scraper) - as good a sharp bowl gouge pretty much.
You may well get the same result without this jig using an alternative burnisher or stone technique ... but I'm impressed.
Toby
Toby
