RogerS
I thought I understood these but now I'm not so sure. Been researching for a new freezer and I see some advertised as built-under at 850mm height and others 815mm and 820mm.
jasonB":aak5v8yf said:820mm under the worktops is a bit on the low side unless you are having nice granite tops with a mitred downstand :wink:
I usually fit Neff and they vent through a grill at the bottom and can be fitted tight to the underside of the WT, usually end up with about 70-80mm of the adjustable legs wound out.
Jason
