JonHowes
Hi, This has probably been answered before although I can't find the information:
I've gained planning permission for a large workshop in my garden. It is over 50 square metres so needs building regs approval. I want to get on with the build and am wondering how much detail normally goes into a building regs application for a project like this.
It is a timber structure skinned with trad corrugated steel. I've done structural calcs for base, wall and roof and written these up including a finite element analysis of some truss beams needed for the roof (I'm an Aero-Engineer so this is home territory).
I've prepared construction drawings of most elements such as base, frames, skinning, structural details etc and also a rough drainage scheme (sloping plot)
Although I have outlined routing of wiring I have not done anything on electrical compliance as I am hiring a specialist for this. Other than making sure that there is space for wires in the right places this aspect will not be ready until later in the build.
The building control application isn't clear about the minimum acceptable level of detail. Can anyone advise? Does it cause a major issue if the detail isn't complete on initial application?
Thanks in advance for any help.
Jon
Jon
