Hello everyone,
I'm looking to build a portable pc case with built in screen out of 4mm thick baltic birch plywood and I was wondering if it will be rigid enough to hold about 5kg worth of parts in a box with a 40cm x 35cm base and a height of 9cm?
The other alternative is to construct a case with 0.5mm thick aluminium sheet and bond 3mm plywood to it on the outside.
Which one would be better for case rigidity? I would also be interested in alternative materials that you may know of but the total mass of the case has to be under 1.5kg.
Does anyone know the density of birch plywood? I've been using 0.65g/cm3 (~40 lb/ft3) to estimate how much the case will weigh.
I'm from south east London and I was wondering if anyone here could recommend a place where I can get some 4mm baltic birch if that ends up being the plywood I go for.
Advice will be appreciated.
Thanks for reading.
Thanks for reading.
